Custom header problem with wp rocket plugin!
I added a header from the global template and afterward had this issue, you can check in the screenshot.
Screenshot Img
ERROR
Warning: getimagesize(): Peer certificate CN=*.sgcpanel.com' did not match expected CN=investingsimple.blog’ in /home/inves419/public_html/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 639
Warning: getimagesize(): Failed to enable crypto in /home/inves419/public_html/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 639
Warning: getimagesize(https://investingsimple.blog/wp-content/uploads/2019/01/investingsimple-logo.png): failed to open stream: operation failed in /home/inves419/public_html/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 639
  • This topic was modified 7 years by IS.
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
Hi, i deactivated all non tagdiv plugins including wp rocket.
After that i purged everything from cloudflare, still the cloud template won’t work normally and i end up with the error code above my header referring to line 639.
I do have some backups of my website, what should i do now?
Please make sure that WP Debug is set on false like in our documentation -> https://forum.tagdiv.com/requirements-for-newspaper/
If the problem is still there, please delete( delete the theme, theme plugins too, do not override ) the current version of Newspaper that you have and download again the last version from themefores and reinstall it.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
