Custom label not on flex blocks?
Hello
On the 11.4 changelog – it says that the new custom label feature ( extra label ) is on all flex items
But on my update it only appears in the TDC settings for flex grids – not flex blocks – am I missing something?
Pat
Hello Pat,
You can set the custom label in the posts -> https://i.imgur.com/gTtAQRv.png and this will be displayed for Flex Block and Big Grid Flex -> https://i.imgur.com/3Uop58r.jpg
Thanks Anamaria
But it isn’t on Flex Blocks – only on Flex Big Grids?
I understand it and it works on grids – but there is no option in ‘Layout’ on blocks like Flex Block 1 for example for the custom label
Pat
The option is available on all flex blocks -> https://i.imgur.com/BtvJLEy.png -> https://i.imgur.com/BtvJLEy.png
The option isn’t available on my composer options for any Flex Block – only for Flex Grids
See this one for Flex Block 1
Version is 11.4.1
Please provide a video.
This is a strange situation because I made a test, and for me works well -> https://www.screencast.com/t/GcShysiNau please if you can do a test using the theme plugins, clear all cache and see if the issue persists.
Let me know the results!
It’s a child theme after TagDiv customisation work, but has always updated ok with other recent updates – could that be the issue?
Will do the plugins check as soon as I can Anamaria
Hi Anamaria
No plugin conflict I can find
One strange thing is that the custom work from Tagdiv adds the ‘live category tag’ options to all flex blocks – this new label should appear near to that menu item that I have on my theme – but doesn’t
The Big Grids do not have the ‘live category tag’ option from TD custom work, but the new label option DOES appear on FlexGrids
As I said though the custom work was a few updates ago and all has been fine until this improvement
Cheers
Pat
It also shows on Post Loop – so it’s just all Flex Blocks where it does not show
We can take a look at this. Contact us via email at contact@tagdiv.com and provide the following:
– wp-admin (URL and credentials)
– cPanel (URL and credentials)
Thank you all emailed
Hi Anamaria
I had an email from support and replied to it – but they think that the TagDiv customisation work has stopped working – that is not the case, the customisation works well.
To note: Custom label works on post loop and big grid flex – does not work on Flex blocks –
I can’t find their email to me from this morning or my reply to them – can you see if yourself and / or Simon – Bogdan have received it – I also reserve the video from this forum which shows the issue
*re-sent the video
Hello Pat!
If you sent an email, then we will take a look and reply to you as soon as possible.
Please continue the discussion via email.
Thank you for understanding!
Viewing 16 posts - 1 through 16 (of 16 total)
