Custom Post Design Loading Fine on Desktop but Not on Mobile Devices
Hi Team, first of all, thank you for such an outstanding theme. My team is developing a Plugin with Custom Design that is working fine on desktop (just header is having an issue) but when we open the same link on mobile devices or even in responsive mode the design doesn’t show (or load).
URL: https://bit.ly/3fNsY2Q
Hi, It’s been more than 24 hours since I’ve not got a response?
Hi, I am looking for response.
Thanks Team
In the future, please try not to reply multiple times in the topic if possible, this will only delay our response. Replying multiple times will refresh the topic date and move it to the back of the line, we answer from oldest to newest.
Also Monday and Tuesday were two holidays in Romania (20-11/01-12-2020).
This is because you are using the mobile theme plugin, using this plugin the mobile version will be faster, but will display less options and you need to use new content in mobile editor for pages. To have the have content and design on mobile as on desktop, please disable the mobile theme plugin.
Thanks for informing; I have imported the Gadgets Theme on my blog https://bit.ly/39S59G9 but I am facing a problem in the mobile header the default menu is set and the logo isn’t changed even though I’ve changed it in theme panel.
Hi techwafer, if you are referring to the mobile logo from responsive version, this can be edited using tagDiv Composer, Gadgets Pro demo is a SVG -> https://i.imgur.com/kPqFepY.png with a text logo -> https://i.imgur.com/qX3AAJM.png -> https://i.imgur.com/30Wb9ck.png
Hope this will help you!
