Customization Help
I need help with the following:
1- How to I move my logo to the left so it aligned with the rest of the site on the left
2- How do I add an html text link to the right of the date in the top header bar. I would like it to say “LISTEN LIVE”
3- How do I make that same top bar appear on mobile?
4- I am having some cache issues with the site. Ex – I change the social icons to just two but it is still showing 5 icons on my end.
My site
https://balrajdesign.com/winnfm/
Hello !
1. On mobile you cannot move the logo because it will overlay the menu button: https://www.screencast.com/t/Qx9qcKYRvY6
2. I see that you have already added this button
3. Unfortunately that option is not possible. The top bar will appear only on mobile menu
4. For cache please follow our tutorial here: https://forum.tagdiv.com/cache-plugin-install-and-configure/
One more issue
How do I reduce the spacing between these columns on my page?
https://balrajdesign.com/winnfm/covid19/
The section is located in the middle where it says “Numbers From Around The Caribbean”
The spacing below each of the 12 blocks area too large
If the page was made with TagDiv Composer, you need to edit it, click on that element and click on the column from that row, after that in css set a margin and padding for left and right lets say 0 -> https://i.imgur.com/iUomjmI.png
Hope this will help you!
I want to remove the bottom spacing
here is my screenshot
https://ibb.co/ww4xm5V
Yes, I am using TagDive Composer
The bottom spacing and be remove as in above example, but you need to set a the margin bottom and top on elements -> https://i.imgur.com/nI07986.png
