Customize sidebar for post layout
How to fix this? http://prntscr.com/ojgx3y
I need to customize sidebar post from Newspapper, cause native mode doesnt allow the “style” option http://prntscr.com/ojgydh
“Style particular content element differently – add a class name and refer to it in custom CSS”
Yes, this can be achieve using custom css ->https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/ if you need help with this just let me know!
Hey, Calin, I do need help with it. I tried, but it didnt work. I think there is another way, cause i already have the Newspaper theme and worked diferent, but i dont remember what i did.
Example, i need to cutomize title box colocar and put that style on social counter: http://prntscr.com/ojvf18
Hello !
You can customize your sidebars using the tagDiv Composer and edit them in every way you want as you can see here: https://www.screencast.com/t/xJWl2z2i3U
So, how can I cutomize the sidebar’s posts via tagdiv? i already did on main page, but i’m trying to do this in posts template
ello !
The only way to have this feature is to do the following:
In homepage edit using the tagdiv composer and set the row layout as shown here: https://www.screencast.com/t/zQcJSXzW You only choose one sidebar not 2.
Edit the ROW and set the layout to have 1 sidebar and you can add the elements you want.
In order to have this in posts you will have to add a single post template from the cloud library: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
