Default "ARTICLE DISPLAY VIEW" for custom post type
I have several Custom Post Types and I would like to set a DEFAULT POST TYPE TEMPLATE to each post type. https://imgur.com/a/3aeK7kr
Is that possible?
I have a site wide option:
https://imgur.com/a/GLkusZM
And a default option per post (if it is not a custom post type):
https://imgur.com/a/8AGzhz8
When I am in a custom post type creatio form I have no per post option neither, wich would be a bit hard but would work as well.
https://imgur.com/a/lVNp7Kr
Please change the TOPIC title to “DEFAULT POST TYPE TEMPLATE” for custom post type
By default the custom post types will use the default post template. You can create a custom template for each custom post type (based on the other post template styles), as mentioned in this guide (at the bottom)
– https://forum.tagdiv.com/custom-post-type-support/
In the theme the settings and options for custom post types are limited, they will not share the same options as default post types, or the cloud library templates. Maybe this will chnage in the future and more features will be added.
