Design and layout help web and mobile
I have the Newspaper 8.5 theme running on my site and would like to tweak its visual appearance on web and mobile. I would like to hire a designer who is experienced in Newspaper 8.5 to help with layout specific to my audience. Where would I find a designer with this experience and how much might this cost?
Needs: Mailchimp form in footer on mobile, fix category menu, possibly design static homepage.
Thx epickenyan – I am looking for someone who already knows the Newspaper theme well… I searched envato and didn’t find anyone – can you help me find someone on that site?
You could try and make the customization yourself. We do not have a customization department but we will try yo help you as best we can.
Maybe there is no need for modifications at all, or not so many, the theme may already have options for what you want to do. For example a Mailchimp form in footer could be entered in the widgets section. The footer has sections in which you can display any widget you want
– https://forum.tagdiv.com/footer-templates/
You can even display a whole page in the footer
– https://www.screencast.com/t/cTVSgxvUJ0F
