1) Via tagdiv editor, I see this on laptop
On Mobile I see this
How do I achieve https://ibb.co/JsvVcHg on mobile?
1) Suppose I want the latest post in category as featured
In the second row, I want to display same category but not the latest post as it shows odd. How can this be achieved?
1. Please deactivate the mobile theme plugin, clear all cache and check the results.
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
2.A solution is to set the offset posts on the blocks => https://www.screencast.com/t/Tsiu65TSaRS -> https://www.screencast.com/t/YbkmVbsBrnk
You can use the Flex Block 1 and you can filter it to display the posts only from a category -> https://i.imgur.com/Nnt3zGX.png and you can design it to look like a posts loops block.
