Could you please tell me how to set up different header style for home page and posts?
I would like to put header style 10 (logo on the top and main menu below)for the home page and header style 7 (logo on the left and main menu on the right) for all the post pages.
Open the different pages via. TagDiv composer, when you open the page click “header options”, and pick a template.
You can edit the template via. the composer.
On posts specifically, open the “Cloud Templates” option, and choose the Single Post Page.
Hope this helped.
You need to have the latest theme version (9.5) and have the cloud library plugin active. Then, you can use the header manager like so: https://tagdiv.com/newspaper-theme-customize-the-header-manager/
Hi. I’m having the same problem. I created my own home page and header (without a template) but that same header is not transferring to my posts. How can I create a global custom header for posts?
If you want to have the header that you create set global to all post/pages … you need to set it from theme panel -> https://www.screencast.com/t/bZYGcjg7KRD
I am still confused.
I want to create one type of header for my homepage and another type of header for all my posts. If I do it the way you showed in the screenshot, then header for both homepage and post pages will change.
I am really new to WordPress.Could you please send step-by-step screenshots about how to do it?
Thank you and your help is very appreciated!
Jeanne
If you want to have a header for homepage all you need to do is to set on that page a header and that have will apply on that page, the general header will apply only on page/post/category that do not have set an individual header.
https://www.screencast.com/t/d35iJiy0
Hi – I have the same question as Jeanne. Would you please answer it?
“I want to create one type of header for my homepage and another type of header for all my posts.” either through the new Header manager or the old theme options.
And a second question, how do you use the new Header Manager on posts?
Maybe I was not clear enough, lets try again.
If you want to have a global header you’ll need to set it in theme panel -> https://www.screencast.com/t/bZYGcjg7KRD and all pages/categories/posts that do not have set an individual header will have that header set.
For individual header you’ll need to edit that page/post template/category template… and set in it the header that you want, and on this posts/categories templates or page will be set that header ( the individual will override the global header for that post/page ).
So in order to use it on post, or you set a global header our you use a single post template from tagdiv Cloud Library and set on it a header after that you set the template on posts.
