Hi, I recently purchase the Newspapertheme and currently using default theme and setting
As when I installed demo content “Style Pro” and try other demo theme also, with Standard Pack and Without Standard pack.
1.-I did not get default Comment section as you shown you “style pro theme”.
2.-Can you suggest Which demo Theme Name is best for High GTmatrix Rating.?
1. For you in order to let a comment, you need to log in -> https://i.imgur.com/sk7fZq4.png if you do not want the visitor to log for comments, you can check these settings -> https://i.imgur.com/pQyWzMd.png
2. For High GTmatrix Rating you can use any theme, because the page speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Hope this will help you!
