optimize script to improve site speed
How can I improve site performance from script without affecting the site?
loading is too slow
my site is http://portaldarmc.com.br
Please notice that the speed of your website depends on how well your site is optimized.
Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/
There are many optimization guides provided by our users here in the forum, some made by us, you could check some of them
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
– https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
– https://forum.tagdiv.com/topic/sql-querys-high-cpu/
– https://forum.tagdiv.com/topic/newspaper-theme-slow-to-respond/
– https://premium.wpmudev.org/blog/optimizing-your-wordpress-database-a-complete-guide/
– https://underconstructionpage.com/optimize-wordpress-database/
– https://crunchify.com/better-optimize-wordpress-database-all-in-one-guide/
Thanks your replay.
So Newspaper theme is not optimized theme, your advertisement is full Lying.. BIG CHEATING .!!! I thought its theme already set everything.. VERY SAD…!!
Hi expertek,
I think that you got it a little wrong!
There is no premium theme that can provide for any content over 90 speed, the page speed depends a lot of your content, if you are using small images and more text then the theme will be faster, also if you do not use the mega menu it will be more faster and so on. But if you want to have a nice website and an attractive one, then you’ll use different style and options, a lot of images, videos and most of text will be only inside the posts. When you do this, then you’ll need to use other methods to make the site faster, because the content became bigger. All these optimize can not be achieve using only the theme, therefore you’ll need a cache plugin, maybe a CDN and so on.
Here are some articles about this:
Why Page Speed Matters and How to Improve It
Page Speed
About PageSpeed Insights
Also you can make some tests: for example use only the theme without theme plugins, then you’ll have a simple theme like these free from WordPressn and you’ll not be able to do anything spatial, but the page speed will be quite good, after that activate tagdiv Composer and standard pack, install a standard demo and check again, then the last test disable the standard pack and activate the cloud template and install a pro demo. You’ll see that the more options and effects the theme has the speed will be a little lower and this is happen with all big/premium themes.
I think the user is referring to the claims on theme forest.
https://i.imgur.com/gYs6vlP.png
It states 98/100 Excellent Google Optimization.
With my site and a fresh install I got a speed of 20/100 on mobile, then I followed all the suggestions from support
– https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://tagdiv.com/how-to-increase-page-loading-speed/
And now I’m at a 28/100 on mobile.
Is there a solution for this or was the claim on Theme Forest unfounded?
  • This reply was modified 5 years by Heels.News. Reason: clarification that the stats are for mobile
Hi Heels.News,
Only installing a theme will not provide 98/100 speed, you also need to optimized it, please make some teste with our live demos https://demo.tagdiv.com/select_demo/select_demo_newspaper/
Those are optimize using the above guide, also for mobile is use the mobile page template, also we are using the new tool css analyzer https://tagdiv.com/whats-new-in-the-newspaper-theme-10-4-update/
Hope this will help you!
The conclusion is that wordpress is not the answer because of speed. The answer is to switch to a managed service.
