Display posts from other web
I am using Tagdiv composer for homepage. Is there ane possibility how can I display also posts from other webpage? It is relatively common feature in wordpress…
thank you
Widgets, RSS or Plugins should do the trick.
Which one?
Unfortunately, we do not have any tested plugin in order to achieve this.
You can test/use which one is suitable for your needs, but please take care for a future plugin conflict.
thank you for reply :).
How can I test some plugin to achieve this? The problem is that in Tagdiv builder there are some prebuilded widgets, and no one has this functionality, and how can I use other than prebulded widget in tagdiv on homescreen? Some widget which shrtcodes will display in example…?
Yes, we do not have this functionality. To add a shortcode in TagDiv Composer, you should use the element called “Column text”.
For example step 3 here: https://forum.tagdiv.com/add-cryptocurrency-price-ticker-widget/
Hope that helps you!
thank you,
but there uprise a new problem with Column text. Whe I want to edit conted, the loading wheel is displayed and never stops.
DO you know where should be the problem? 🙂
