Hello
I want to display subcategories instead categories on Block 1 head.
How can i do it?
https://www.imageupload.co.uk/images/2015/08/09/Capture.png
Under the Ajax filter tab you have this field: “Ajax dropdown – show the following IDs:”
These are the IDs of specific categories to show.
To get the ID of a category, go to Posts -> Categories in your dashboard, and hover over the Edit button for that category. Look at the URL, which will include a number like “&tag_ID=23”.
Find the IDs of the subcategories you want to show and enter them into “Ajax dropdown – show the following IDs:”
Thanks @TheMediumUTM!
@notpedu
Please check this guide about block setting(Ajax Filter Tab) – https://forum.tagdiv.com/block-settings-tutorial/ just set ajax filter type by categories and paste the subcategories IDs that you want to display there – http://screencast.com/t/jInXuOH0TUz you can take the ID like this – http://screencast.com/t/7IGPRmU8i
Result: http://screencast.com/t/DcnaU01fD
