Do not work on mobile
Hello people,
Some pages on my website (www.corridaesporteclube.com.br), do not work on mobile.
Attached, I am putting some evidence. In these pages, you have contact form (Plugin: FormCraft), events (Plugin: EventON) and (Plugin: Table Builder).
https://corridaesporteclube.com.br/wp-content/uploads/2020/06/Screenshot_20200609-143449_Chrome.jpg
https://corridaesporteclube.com.br/wp-content/uploads/2020/06/Screenshot_20200609-143439_Chrome.jpg
https://corridaesporteclube.com.br/wp-content/uploads/2020/06/Screenshot_20200609-143428_Chrome.jpg
https://corridaesporteclube.com.br/wp-content/uploads/2020/06/Screenshot_20200609-143417_Chrome.jpg
I’ve used other plugins, however, none work with the NewsPaper template.
can you help me?
Using the mobile theme plugin, you’ll gain a better speed then responsive version of theme, but in order to achieve that speed you’ll need to create a new content for pages because in the most of cases those were made with builders ( tagDiv Composer, WPBakery ) and you need to use only the mobile editor ( you need to set the content for pages in mobile editor and this content will be display on mobile theme)
-> https://i.imgur.com/9d0UWLT.png
Also you can show the responsive version on mobile theme -> https://i.imgur.com/m0bVB5T.png you can check more details about mobile theme in our documentation -> https://forum.tagdiv.com/the-mobile-theme/ or if you want to have the responsive version only, you can use the amp option from mobile theme -> https://i.imgur.com/oofST3D.png (to use the mobile theme template on amp) or you can disable the plugin.
