do not work with autoptimize and "Above The Fold Optimization"
Hi there,
both plugins, autoptimize and Above The Fold Optimization damage the new version 7. i had to deactivate them, otherwise there would be a strange behaviour of my site (showed a kind of mobile menu on desktop or some code before showing the page). Do you know abaout this behaviour, do you have a workaround or a hint, how to get manage this?
Beste Grüße, Frank
Unfortunately this is the case with every premium theme. Not all plugins are compatible and when major updates are released, some plugins could stop working or others could start working as the code gets changed. The code is custom in a premium theme and plugins are created based on the wordpress default code. That is why incompatibility happens. unfortunately there is little we can do in this matter.
ok, thanks for your reply. so a premium theme should handle with “above the fold” natively – without plugin, shoudnt it? or it should give some alterniative and working plugins for it 🙂
Our theme does provide an alternative as you can see in this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
Also a few notes on speedbooster: https://forum.tagdiv.com/topic/incompatible-plugin-detected/
So do you intend to fix this issue as I am having similar issues?
Regards,
Dave
This is not an issue, but a plugin incompatibility. Please use the guide I posted above to speed up your site and not third party untested plugins.
