Just found the reviews tab: https://imgur.com/a/jTowyTk
Does this help with SEO? Does it affect pagespeed times?
That option is just and sample review will no affect you SEO and pagespeed,
If you want you can check our documentation for reviews here -> https://forum.tagdiv.com/reviews-2/
