Downloads not showing on Mobile Phones.
Greetings,
I have a number of downloads on the website but only one file displays when I visit the downloads page.
Could you help me rectify this issue. The downloads are displaying well on PC but not on mobile.
the website url is https://solwezitoday.com/ and the downloads url is https://solwezitoday.com/magazines/
I just checked your website and on mobile it looks that the rest of the “downloads” can not be loaded -> https://i.imgur.com/W0KoxfU.png the problems are from here https://i.imgur.com/z7mjorE.png
Now on that page do you use the mobile theme plugin? or the responsive version?
Please make a test and disable the mobile theme plugin and check to see if the problem persists.
Let me know the results!
I am using the mobile theme plugin.
Let me try to disable the mobile theme plugin and see what we get
After disabling the Plugin. I can not see any downloads at all from the Mobile version of the website. See https://imgur.com/a/SN5eOfn
Hi sumasystems,
If I understand correctly, right now, you are using the mobile theme plugin, if is o, I think that this is disabled on that page using this option -> https://i.imgur.com/TGRbzfK.png in this way the content that is display on desktop will be display on mobile too.
If you already did that and is not working, please make a test using only the theme plugins and in case that the problem is still persisting, please contact us at contact@tagdiv.com and provide wp-admin access. We’ll check it as soon as possible!
I also keep getting this error.
Error at zones: 6(models) : 5(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Please contact us by email that my colleague provided you contact@tagdiv.com
