Hi, great theme, im just starting out,
i would like to create a post using the template import and tagdiv builder.
(creating a post similar to the home page nature template https://demo.tagdiv.com/newspaper_nature/)
i dont want to use a page for this since i want it categorized.
any ideas how to achieve this ?
thanks
Hello !
You can use for that the Single post template from the Cloud library.
Please take a look at this tutorial to find out how to implement it: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
Hi Vlad, good tutorial but when i add the template from the
“Pre-designed Templates – tagDiv Cloud Library”, (nature home page template for example) it is added as a new page and not as a post template (and does not appear in the post setting-> post template)
also, it does not appear in the “Cloud Templates” list.
am i doing something wrong?
Hello !
You have to import it all the way, save the settings from the tagDiv Composer and then set it from here: https://www.screencast.com/t/fNuNXF8lfVx7
Let me know how this went !
Hi Vlad, nope, something is not right,
first, it says create page when i pick a template from the cloud templates – new
http://prntscr.com/ou4a9b
and even after i import it, it doesnt appear in post theme settings,as you can see
http://prntscr.com/ou4aka
Hello !
You are trying to import a HOMEPAGE not a POST TEMPLATE as you can see here you will have to go into SINGLE tab and import from there: https://www.screencast.com/t/l0Z6ZUNaAc2F
