Bought Newspaper 9 theme yesterday, sadly cannot use ” Edit with TD Composer”: I get a grey screen. What to do?
Still no solution to grey screen “edit with TD composer” from customer support: is there an easy fix for a non tech person?
Hello David,
Did you have checked your system status parameters to be increased according to our documentation from here -> https://forum.tagdiv.com/requirements-for-newspaper/
Hi Catalin,
As far as I (non tech person) can see: no problems/warnings on the “Newspaper system status”. Is there another solution?
Hello David,
Ensure that your theme has the latest version of it, remove all of the untested plugins, clear all the caches and check the results. Also, if the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to your setup page. Provide the link to this topic so we can quickly identify you.
