Edit with TD Composer not working on home page
On my site – gkkhoj.com
Edit with TD Composer not working on home page. This option doesn’t shows.
same for me.. doest work. it says “this page was not created with tagdiv composer” or something like that. I did try fresh new install and nothing
Please make sure that you do not have any plugin conflicts, please deactivate all non theme plugins, clear all cache and try again.
Please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
– https://tagdiv.com/newspaper-theme-requirements/
and please increase all requirements that are lower, and follow all steps;
Especially check the php version, wp memory and the code for .htaccess
Also please check our documentation for When tagDiv Composer is not working -> https://forum.tagdiv.com/tagdiv-composer-not-working/
If there is still a problem please provide some more details and some screenshots with this problem.
same problem
Hi @TheDogoholic,
Please make sure that you make the steps above.
If you are referring to this notice -> https://www.screencast.com/t/fOCy4qZByA this appears only when you edit/update the page/template from backed -> https://www.screencast.com/t/wwSJ0MCIaxq and not from tagDiv Composer -> https://www.screencast.com/t/tDGGtPz9zaP
If there is still a problem, please provide some more details and some screenshots with this problem.
