Enquiry on Pinning post on home page and side bar
Would it be possible to pin a post on the home page, and at post side bar? (related posts)
May I also know if there is such a plugin for endless scrolling?
E.g, one article, and scroll down to another article. Thank you.
Hello @bitfinsider!
You can achieve this with the TagDiv Composer. Steps:
1. Add 1 row (or existing one)
2. Split into 2 columns( 2/3 + 1/3 )
3. You can add whatever element you want into the second column and consider it a sidebar.
Use the element called “Posts Loop” where you have an infinite loading feature in pagination. There you have all the necessary settings: https://forum.tagdiv.com/posts-loop/
Thanks, I’ve managed to pin post by creating a new category.
Regarding Infinite loop – I meant it like this https://coingape.com/why-bitcoin-maxis-should-worry-about-this-data/ , is it possible to do it like this? whereby If i scroll down, it would bring me to load the next article
The post loop is not what I’ve mentioned. Thank you Bettina
Hello @bitfinsider!
Yes, check these settings for infinite scroll: https://www.screencast.com/t/cf6aUWlrSBkZ on a single cloud template.
Dear Bettina, Many thanks! I’ve manage to found it!
Also, if i would like to change my blog to an entire new template, is there anyway i could test it out first before going live? Like a staging environment?
Thank you
Yes there are hosts that allow you to create a staging for tests or you can use a subdomain or localhost so you can test what you need -> https://www.wpbeginner.com/wp-tutorials/how-to-create-staging-environment-for-a-wordpress-site/
