Hello. I install newspaper theme and regularly getting error 500 when working in dashboard. And error 500 in posts.
And my dashboard works very slow. I use VPS hosting.
I use latest versions of this plugins:
- All In One SEO Pack
- Disqus Comment System
- Easy Social Share Buttons for WordPress
- FeedBurner FeedSmith
- Google XML Sitemaps
- Ninja Popups
- Russian Date (utf-8)
- RusToLat
- WordPress Database Backup
- WP Super Cache
- WP-Mail-SMTP
- WP-PageNavi
- WPBakery Visual Composer
In logs i see this:
[Wed Mar 02 01:29:37 2016] [warn] [client 31.31.203.70] (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server, referer: http://fototips.ru/camera-test/obzor-obektiva-samyang-35mm-f1-4/
[Wed Mar 02 01:29:37 2016] [error] [client 31.31.203.70] Premature end of script headers: index.php, referer: http://fototips.ru/camera-test/obzor-obektiva-samyang-35mm-f1-4/
and this
[Tue Mar 01 22:50:39 2016] [error] [client] Premature end of script headers: admin-ajax.php, referer: http://site.ru/wp-admin/post.php?post=15692&action=edit
[Tue Mar 01 22:50:40 2016] [warn] [client] (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server
Help me please!
The most common cause of this issue is the plugins you use. Please disable all plugins except visual composer, clear cache and reset cdn if you use it. If there is a plugin conflict, this will fix it. Then you need to identify the plugin that causes it.
Here are the requirements for newspaper you will have to meet: https://forum.tagdiv.com/requirements-for-newspaper/ and also increase these parameters here: https://forum.tagdiv.com/system-status-parameters-guide/
Your question depends on the amount of visits per day as shown in the requirements section.
I hope this helps.
I make everything from it except Suhosin and take more powerful hosting. But on hosting i have problem with kernel: [9131066.484467] Out of memory in UB 2619507: OOM killed process 16605 (httpd) score 0 vm:75504kB, rss:45404kB, swap:0kB
But dont have 500 error now 🙂
Can you help me with memory problem?
Please check your php.ini on your host and check the max_input_vars. The value does not seem to show up in your screenshot. You can contact your hosting provider if you do not have access to the file. You can also let your provider know about this error.
