Hello
suddenly editing the homepage in composer I see this error
“Errors at columns: 2(models) : 5(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
The backend editor shows the page correctly, while in frontend the right column is displayed below the content (and not on the right)
What does that error mean and how to fix?
I can give backend admin but would like to know what caused the issue in order not to make things break again
Please check topic with the same error https://forum.tagdiv.com/topic/error-blocking-tagdiv-composer/
Also, please check if the error appears on other pages/posts.
I checked but the content has all closing tags
I am trying to recreate the page and when adding custom post types in block filters under every (custom) post I see the alert below
"WP booster error:
td_module: td_module_single($post): $post is not WP_Post"
2. The error appears on one other page.
I deactivated and deleted tagDiv composer, then reinstalled it but nothing changed
The issue apparently is connected to custom post types. (not custom shortcodes)
If I use only “post” as post type filter, the issue seems fixed (I admit I only tried publishing 2 test posts)
The custom post types are standard posts with some other meta data and they used to work up to last week,
Please make a full backup, send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you. Let us know and we will gladly assist you.
