Hi team.
My site: vietnamtruyengiao.org
I have create menu by category.
But when i click on menu with category https://vietnamtruyengiao.org/category/ky-trai-vntg/trai-ngu-tuan/ or https://vietnamtruyengiao.org/category/ky-trai-vntg/trai-nhan-ky/ …. when it show error front-end. But with category https://vietnamtruyengiao.org/category/ky-trai-vntg/giang-sinh/ or https://vietnamtruyengiao.org/category/ky-trai-vntg/trai-he/ it show up ok.
Can you help me fix?
Please do these steps
1. disable tagDiv Composer
2. uninstall tagDiv Composer
4. re-install tagDiv Composer it again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate tagDiv Composer
Also, make sure your WordPress and plugins are up to date.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Let me know about your results!
Please make sure that all theme requirements were set as in our guide https://forum.tagdiv.com/requirements-for-newspaper/
Here is an article about how to fix this problem:
There has been a critical error on your website. => https://www.wpfixit.com/wordpress-error-there-has-been-a-critical-error-on-your-website/
Hope it will help you!
