Error with mobile and posts
Item Purchase Code:
Just purchased your newspaper theme and having 2 issues.
1) Mobile theme sometimes work but always reverts back to desktop theme. I don’t have jetpack or any other mobile theme installed.
2) On post page can not find a way to limit to 1 post… most keep loading one after the other to infinity.
See example at https://www.canindia.com/ontario-expanding-covid-19-testing-locations-pharmacies-to-provide-test-services-for-symptomatic-individuals/
The Domain is http://www.canindia.com
  • This topic was modified 4 years by Calin.
Please do not share your private license on forum (once that you have access on forum means that you have a valid license key).
1. Are you using the mobile theme plugin? Maybe this is a cache problem. Please provide some more details and some screenshots.
2. If I’m right you are referring to infinite loading (the posts that are loading at the end of the accessed post), for this, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
I hope this will help you!
