Hi!
I’m having troubles with my new demo. I installed the Newspaper Travel Pro last week, but until now some problems are happening.
First, I can’t upload my own photo on the author space in home page. There’s no option of circle photo and when I try to upload it, the page goes down with an error.
Second, I can’t change the images on “Destinos Espetaculares”, or demo’s English “Top Destinations”. There are four images there, from the demo, and I can’t change it. When I try, it appears an error too.
Third, the default template for the posts it’s not working in links. For example, I have so many links in my posts to another posts, but when I click on it, appears a different model from the post template of Newspaper Travel Pro’s demo.
Can anyone help me? I have screenshots from the errors, if it helps.
Best regards,
Amanda
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all plugins and child theme ( if you are using ) and let only the tagDiv Composer , clear all cache, deactivate the cache plugin and try again.
Also make sure that all theme requirements are set as in our guide -> https://forum.tagdiv.com/requirements-for-newspaper/
