Exactly how do I specify only 5 static posts for a Big Grid Flex 5?
On my homepage, I have a Big Grid Flex 5 block. I want only four specific posts here, and I don’t want it to change as I add other posts to the site. Overall, I have 2 categories. For example, I want 2 posts (id:857 and id:672) from 1 category, and 2 posts from the other (id:868 and id:492). And I want them ordered: the big picture on the left be 868, and to the right of that, I want 492, then the 2 smaller pictures be 672 and 857.
I know your tutorial says “Post ID filter – Specific posts can be filtered to your block by using the post ID. You can get the post ID by accessing Wp Admin > Posts section, hover the post title and check the link displayed on the browser left-bottom area. The IDs can be extracted from this URL. In order to exclude posts from a Big grid just add a ‘-’ symbol in front of each ID.”
My question is, using your TD composer, what exactly do I put into the FILTERS box? And I want these posts to be “unique” on the page.
Oops, just notice my Topic for this post says 5 posts in “Big Grid 5”. I meant to say 4 posts.
  • This topic was modified 6 years by reedesign.
The number of post displaying in Big Grid Flex 5 can not be changes, but you can set the post id like this -> https://i.imgur.com/lAw0ZzU.png -> https://i.imgur.com/5rryFvb.jpg also in order to have a unique post you can use the Unique articles, (this option is working only with tagDiv Standard pack) -> https://i.imgur.com/GSu8qE5.png
