Excluding posts from "More Articles Box"
is it possible to prevent posts with some very specific tag from being displayed inside a “More Articles Box”, which appears after you scroll to the bottom of the article?
For example, I’d like to not suggest articles tagged as “archived”.
I would be very grateful for any tips or guidance on how to achieve this.
Thank you
The more articles box has settings to control the posts that are displayed in it
https://forum.tagdiv.com/more-articles-box/
You can choose a common point, and only articles that match will be shown.
