facing a big problem
hello
every day i facing a big issu while loading website – wwwnavadharacom
every day it show a error message, i am using godaddy server.
error is :
“Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Additionally, a 503 Service Unavailable error was encountered while trying to use an ErrorDocument to handle the request.”
why happened this??
Maybe it should be best if you inquire about these server problems with the hosting you currently are using. Perhaps they could have a better answer related tho the errors.
These are the theme requirements for the server
And modifications made to these parameters if needed, according to this guide
