Hi all.
I’m trying to remove More Article as i don’t like to have long scroll down but the button in theme funnel it’s not working, please help me to fix this issue, what is the solution, and i found some other buttons are also not working, many bugs i found in the theme.
thank you
Adil
Hello !
The more articles box can be disabled from theme panel as you can see here: https://www.screencast.com/t/vm8fqRV8VKD
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
