Feature Image Issue, Sitemap Issue, Ads not showing after posts
Please take a look at the front page of my site, https://theindustry.biz
1. Feature images for logos are not resizing to fit.
2. My sitemap is unable to fetch posts it’s stuck at 0
3. When I add ad code after the posts it is not showing on the site, worked before.
Hello @keverix3 !
1. If you upload an image that is smaller than your size from settings, then this could appear blurry and not of high quality. I suggest you upload the images in your Media Library in full size (1920 px): https://prnt.sc/YzxtrT24bGKM
2. Do you have any error? Check out: https://yoast.com/help/how-to-customize-the-sitemap-index/ -> https://forum.tagdiv.com/topic/sitemap-is-not-opening-i-am-facing-sitemap-error/
3. You can also add the ad code in the theme panel and choose from where you like to display the ad in the shortcode Ad box from tagdiv composer using a cloud template.
If you use default templates, then the ad should be displayed if the code is correct.
Check out the documentation here:
– https://forum.tagdiv.com/ads-adsense-overview/
– https://forum.tagdiv.com/article-ads/
– https://forum.tagdiv.com/background-ads/
– https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
I suggest to deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
1. I am referring to feature images not resizing properly when they are logos (see front page) they boxes are only showing the middle of the image.
#2. When I add affiliate code to the bottom of the posts or in the sidebar, it’s not showing on the front end.
Nothing that you referred me to addresses either issue.
Hello @keverix3 !
1. Please check and upload the same size of your featured images.
2. Let me see the settings you’ve applied.
