I set featured in categories and added it to two posts but it wont display when set in first page in filter.
How do i do that? The page is kriptoblock.si
You can use the Flex Block and you can filter it to display the posts only from a category -> https://i.imgur.com/Nnt3zGX.png
If the posts are not displayed, then, please edit with tagDiv Composer, select the block and let the offset field empty with no space, no value and see the results: https://www.screencast.com/t/peVbVmUDE
For more information about the offset features, please check this tutorial: https://forum.tagdiv.com/offset-feature/.
