featured images not shown on front page
hi
website uses newspaper theme. on front page is not shown featured images. on post settings is “show featured image” active
site uses a “echo rss feed” plugin which fetches/sets featured content image url. with my previous theme was shown correctly. what could be issue?
Make sure you set a featured image for each article: https://forum.tagdiv.com/featured-image-or-video/
this is done by plugin over url. as i wrote with my previous theme works and you can see on post page image is displayed but not in front
Please use the rss feed plugin and check after. Also, please provide some screenshots with your settings https://i.imgur.com/DJHT0KF.png
Works now but plugin has also option “do not copy images locally” which i used so far and with other theme worked. Featured image then was just replaced with image url from external source i assume. Can you test this with your developer as well?
Unfortunately, this plugin that you use has not been tested with the theme. If you want compatibility with this plugin, this can be done with custom work -> https://tagdiv.com/web-development-services/
