Hi, why does this not work?
snipboard.io/v4bmdp.jpg
tags are correct:
snipboard.io/XAc84S.jpg
And same exact problem is even with categories.
It works and brings posts ONLY when “all categories” are selected without any other filter:
snipboard.io/ZB4HDJ.jpg
Please help me fix it.
Hello !
For the tag please try and write it like this: featured not like this: Featured.
Also for the categories you should be able to select any you want from this dropdown: https://www.screencast.com/t/cFvsvd7T Isn’t this option clickable for you ?
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
