Featured posts on flex block 1 not working
When I add an element flex block 1 and if I use the following configuration, no featured post is displayed. Same post is always displayed (last post) and it is not a featured one.
Configuration of the flex block 1 :
– limit post number : 1
– filters tab:
* everything is left blank except sort order and category filter
* category filter : — all categories —
* sort order : Featured
Is there a bug here, or what am I doing wrong. I know how to define a featured post and the way I do it matches your online documentation.
Looking forward to your reply,
Thanks for your help.
Just to be clear… I need to display only featured posts in a random way.
To works you need to have the posts assigned to the category Featured https://forum.tagdiv.com/featured-posts-2/
Thank you for your reply.
Don’t have any featured category… I might have deleted it or renamed it.
– How can I find it ?
– Can I recreate one just by naming it FEATURED and then, how to make it not visible from the website? What do you edit as parameter from the database (table>variable) ?
Regards.
Nevermind… I changed my mind… this is not flexible enough to be used for the aimed purpose.
Regards.
