Hi guys,
First of all congratulations for your great theme, i bought Newspaper a few months ago and i only found the courage to remake my website last month.
So, as you can guess i met tons of details that need to be cleared, even after reading the documentation.
Please can you help me with these questions ?
1. If the plugin Disqus is activated, the main menu bar takes long time to appears, how to resolve that ?
2. Is it possible to modify the size of the top menu bar ? Can’t find this option in the TagDiv Composer,
3. Is it possible to change the order of the social medias ? (on the top menu for exemple),
4. When i try to change the H2 title style, to make it bold from the theme panel, it doesn’t looks like it works,
5.I have 3 articles at the top of the welcome page (Big Grid Flex 4), then the list of the newest article (Posts Loop) : is it possible to start this second list, with exception of N-3 article ? In other words, to start this Posts Loops from the 4th newest article, to avoid repeating the top 3 newest articles,
6. Is it possible to parameter a template page for all pages at once ? Because for now it looks only possible one by one,
7. Is it possible to make a background video without Vimeo or Youtube ? For exemple a local video, or it would be too heavy ?
8. Is the plugin “Lazy load by WP Rocket” is still usefull if the lazy load option included in the theme is actived ?
9.The Flex Box 1 element is not responsive, it appears well on the computer but not on my smartphone : do you have a solution please ?
10. The sidebar widget looks like it appears different from the native theme widget, for exemple the title : how it is possible to have the same widget title style for everything ?
11. On Chrome with a resolution of 1366*768, i have to unzoom to have full complete page composer and make the scrollbar to appear, do you know about this bug ?
12. How is it possible to disable the arrow in each title of the main menu when i choose to activate the mega sub-menu ?
I know it may be a long email but i have all my questions here 🙂
Thank you very much for your help, i highly appreciate your theme and keep the good work.
See you
1. Please notice that the Disqus plugin was not tested with our theme, therefore we can not provide technical support for the provide provide by this plugin, please make sure that you are using this plugin only on posts, not pages.
2. Unfortunately there is no settings for the default top bar to change the size ( height ), only the width -> http://prntscr.com/pt9edo
In order to have more control over the header and top bar we recommend to use a cloud header from tagDiv Cloud Library and edit it with tagDiv Composer
3. Unfortunately for the moment there is no option to set the social media in the order you want, sorry!
4. if the H2 is inside the content, then the settings from theme panel should be apply -> http://prntscr.com/pt9hkq, please provide some more details or a link where I can inspect this problem.
5. So if I understand correctly you want to have unique articles on pages, if is so then you can use this option -> https://forum.tagdiv.com/unique-articles/
6. The page templates are these -> https://forum.tagdiv.com/page-templates-2/the unfortunately there is no settings to make a page template, the design nee to be make with tagDiv Composer.
7. Only the the videos from YouTube will work -> http://prntscr.com/pt9ojh, maybe this option will be add in the coming updates.
8. The WP Rocket plugin was not tested with our theme, therefore I can not say how or it will work properly with our theme, sorry! -> https://www.screencast.com/t/cmPkh9jba4sZ
9. The flex can be adjust for all device individual -> http://prntscr.com/pt9qrl -> http://prntscr.com/pt9r37 you can check more about flex blocks in our documentation from here -> https://forum.tagdiv.com/flex-block-settings-guide/
10. There is an general option in theme panel -> http://prntscr.com/pt9s7p but this will not apply only on block headers that do not have set an individual style.
11. That is happen because the standard width of the website is 1068px -> http://prntscr.com/pt9z53 + margin -> https://www.screencast.com/t/FmgLs3wRkAAS when you edit the page will add and extra width from tagDiv Composer sidebar and some padding on the page content, so this will exceed the 1366px.
12. If you are referring to the mega menu next/prev buttons -> https://www.screencast.com/t/xZxnf7Sq2 then you can hide theme only with custom css, you can try this custom css
.td_block_mega_menu .td-next-prev-wrap{
visibility : hidden;
The code need to be set in Theme panel> Custom code> Custom css
If you still have some questions, or I was not clear enough please let me know!
Hi guys,
A reader of my blog sent me a email saying he often sees error message on my website since i changed the theme :
Warning: getimagesize(https://www.biendansmontravail.fr/wp-content/uploads/2017/09/banniere-bien-dans-mon-travail-2.jpg): failed to open stream: HTTP request failed! HTTP/1.1 503 Service Temporarily Unavailable in /homepages/21/d550560841/htdocs/clickandbuilds/Biendansmontravail/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 639
I’ve never seen it myself, what do you think about it ?
Thanks for your help 🙂
Please make sure that all the settings are like in our requirements, please follow the guide carefully – https://forum.tagdiv.com/requirements-for-newspaper/
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
