Filter blocks – want to separate posts
Hi All,
I want to display the posts of a category in two blocks. the most recent file in the first, the others in a second one. How can I set the filter to do this?
Please provide more information about what you need to achieve, screenshots or an example in order to help you efficiently.
Hi, thank you for the quick answer!
Below you see two blocks, both contain posts from the same category. Block 1 contains the most recent 5, block 2 contains all the posts. What I would like to do is to avoid the overlap of posts, therefore in block 2 i would like to see all the posts EXCEPT the most recent 5.
https://www.screencast.com/t/M3edjyWTady
In this case, you can set up for the 2nd flex block an offset: 5, so won’t be displayed the most recent 5 articles.
