Flex Block 1 Padding/Margin Issue
Hi I’m using the Flex Block 1 at the bottom of this page on the left:
http://horses.animalsvoice.com/tdb_templates/category-template-20-fast-news/
As you can see, it isn’t flush with the left margin. I’ve tried everything I can think of to line it up with all the others, but it won’t budge. I only have two plugins activated and everything else is up-to-date.
Also, at the top of the page, I can’t find anywhere on the Category Grid 1 block settings to choose a category to display there so it apparently reverts to UNCATEGORIZED.
This is a category template -> http://horses.animalsvoice.com/tdb_templates/category-template-20-fast-news/ from tagDiv Cloud Library also please make sure that you set a post in a category -> https://forum.tagdiv.com/featured-posts-2/
Primary Category: Build a clear hierarchy for your website -> https://forum.tagdiv.com/primary-category/
Also for flex please check this section -> https://www.screencast.com/t/xk5EHIyyqGVX
Thank you, Calin! It turns out that the padding issue for the Big Flex block was in the column, not in the block itself, but thank you for the lead! Great theme!
