Fonts not saving in theme panel
I am trying to set custom (google) fonts in the theme panel. After changing the fonts and stylings some are saving and they are displayed on the front end. Others are reverted back to their previous setting after the save. This has happened multiple times.
I am running the latest verion of the theme and all plugins.
Also I notice some of the fonts/stylings are taken from the demo installation (default demo)… I have made a new homepage layout in TD-Composer.. and set style and layout options in the theme panel. Can I just uninstal this demo to remove its influence? Or will that cause I lot of issues if the stylesheet disapears?
What the best way to approach that?
The issue is when the page loads it loads the default font and colour accents. After 2 seconds the custom settings kick in and are displayed correctly…. but the initial load is still the ‘default’ settings. Should I uninstal that demo or should I look to edit the css somewhere. I suppose that would lead to quicker page speed if I did it that way??
Site: theirishplace.com
Hello The Irish Place,
Please notice that each demo has the own fonts used and if you want to change it you should check the Theme panel and change the font from there. Also, if your Theme panel does not have anything, please check your system status parameters to be increased according to our documentation here -> https://forum.tagdiv.com/install-via-ftp/
Hope this helps!
Hey Caitlin,
I think you might have miss-read the message…
I have changed the fonts via the theme panel. They are automatically reverting back to the previous font even after multiple attempts. So I have changed half of them and the half half will not save.
Thanks,
K
I mean I made the changes… then saved them. But nothing on the site changed…. then I checked the theme panel again and the fonts were back to their previous setting.
I changed them again… and saved again… same thing happened. No changes on the site and when reloading the theme panel my edits were not evident.
So I am confused.
I tried this many times over a few days and so far I have not been able to change those font settings.
OK,
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
OK thanks, doing that now…
K
I have changed some wp-config settings and its working out ok now.
1 problem is that open sans is still displaying in the sub-menus and some of the widgets such as the social counter – which is not how it should be.
emailing log in details now.
