Hi there, Iam having problems in widget area and footer.
1- Footer
I enable footer in theme painel in style one, to setup what the site will show on 3 columns as you can see.
https://snag.gy/Zsix3L.jpg
Then the theme already choose what I will show on footer. https://snag.gy/EPenoY.jpg
I checked the widget area and all options are empty. https://snag.gy/EU9JVn.jpg . Isn´t there more options? I thought that we can configure more than one side bar. No?
So I inserted my code in text for the first part of the footer. A subscribe form. https://snag.gy/ZcDFT9.jpg
Then the theme put the DEFAULT option (Editor’s Pick) and what I’d inserted bellow. https://snag.gy/hD5iTn.jpg
I really can´t understand! How can I fix it?
Is there anyway the set more than one sidebar?
Hello emalgumlugardomundo,
I have checked your screenshots and I saw that you are using the Footer style 1. This type of footer template is a default one and those 3 columns are predefined by the theme and you cannot change them but only from the code. If you want to make a custom style for your footer section, I recommend using the footer template style 5 and then adding to the Footer 1/2/3 section the data you will see these on your side. Also, you can edit them as you wish. For more information about Footer section, please check our documentation here -> https://forum.tagdiv.com/footer-templates/
Thank you for the message!
