Footer not displaying
Hello
I have a page https://techat.eu
When I look at the footer settings I have it marked as on.
The preview of the footer page works correctly.
But for some reason it’s not displaying at the bottom of the page.
Hello !
As you can see here we can see the footer is available on your website: https://www.screencast.com/t/rYQMZ8EkuO0
Hey
But it should look like this:
https://www.screencast.com/t/49XxCLywwNpg
At least in the template footer preview it looks like this.
Hello !
it looks like that because you’re editing the Footer page and that is the footer of the editor, not the footer that will be rendered on your page.
I hope this was helpful !
Hey
Ok and I can change the footer that is rendered on my page how?
From widgets?
all the best
Ivar
Hello !
You can edit the footer by going into Pages – Edit footer with tagdiv composer as you can see it here: https://www.screencast.com/t/ai3pyH09uuCa
Find out more about it here: https://forum.tagdiv.com/footer-templates/
Hey
Sadly not really.
1. I am using the correct template:
https://www.screencast.com/t/p0VMohjM
2. When I edit it:
https://www.screencast.com/t/TwTXo9tC
3. It shows the correct one:
https://www.screencast.com/t/hYziKkGxaspv
all the best
Ivar
Hello !
This seems to be your footer page that you will be abe to edit: https://www.screencast.com/t/F4u8Ehe6h
After that you will have to go into footer and add that footer page as you can see it here: https://www.screencast.com/t/DAz1DcMP3G1 Now you should only see the editable footer.
