Footer Problem
I can’t find from where can I edit footer widget, the Editor’s Choice, Popular Posts, and Popular Category, I want to do edit. http://69d.ad9.myftpupload.com/
(Please open the link and see the footer)
Regards
Gadgetsay
HI
Those blocks are predefined in theme’s core and can’t be changed from theme panel or wordpress admin. You will need to edit the footer files and change the implementation or use a footer template which allows you to choose what blocks to display in it. You can use style 5 or style 9 to achieve a similar layout: http://screencast.com/t/WTMAv6shGIP Pease check our documentation for more details in this regard: https://forum.tagdiv.com/footer-templates/
