Hi there,
I am using the Say What? demo theme. When I pull up the home page in Visual Composer, I cannot locate the bottom “Latest Posts” at the bottom right above the footer. I cannot locate the Instagram slider or the other content wihtin the footers. Those widgets that are displayed are not within the normal Appearance > Widget section for me to edit. Instead, Footers 1,2,3 are blank.
Where are these located so I can make edits or are they hardcoded in some how?
Hello piortek,
The Instagram Slider can be edited from Theme panel, Footer section, like this -> http://screencast.com/t/vOXPkvUsf -> http://screencast.com/t/TKxBMJ5l1
For more information about this feature, please check here -> https://forum.tagdiv.com/instagram-widget/
If is not what you mean, please provide more details so I will be able to provide a more accurate response.
