Site:
http://www.thewatercoolernews.com/
I used a prebuilt footer and it functions mainly how it should.
But
1. How do I insert / create a blank footer? When i go to manager it shows prebuilt footers
2. on the current footer how do i remove the bg image? it looks like a bunch of lines at an angle
1. You can import a blank template from tagDiv Cloud Library -> https://i.imgur.com/9j25KDn.png -> https://forum.tagdiv.com/footer-templates/
2. Usually, the color and image are set on the row, so please edit and select the row and go in the tab https://i.imgur.com/iqpxjpt.jpg -> https://forum.tagdiv.com/topic/background-color-of-the-main-menu-be-changed/ please check each row/column/zone and delete the background color -> https://i.imgur.com/1M6tOtL.png.
