https://www.xalkidikipolitiki.gr/new/
In the cloud templated section on the footer template there is no option to edit it with tag div builder on contrast with the other templates where i can see the option edit with tag div composer. Why is this happening?
Also the articles and posts inherit the footer template that i choose right?
The footer templates do not have the button to be edited with tagDiv Composer in the backend. Please check this guide:https://forum.tagdiv.com/footer-templates/
The footer template can be edited only from the frontend if it is assigned, edit a page/post template with tagDiv Composer and go down to the footer. => https://www.screencast.com/t/rpfNhfyrF
We talked about it in this topic: https://forum.tagdiv.com/topic/how-to-edit-footer-template-default-pro-by-tagdiv-composer/
You can use the Global footer template or you can set an individual template on each single post templates from cloud templates. => https://tagdiv.com/how-to-create-a-footer-with-newspaper-theme/
