http://resimekle.com/images/2015/11/09/twitter.jpg
i wanna delete or edit these red texts, how can i do it? i added twitter to footer but it dropped down because of this text. where can i delete or edit?
Hi ibomax,
As i can see in your screenshot, you are using a footer template style 1 with these 3 columns, by default (Editor Picks/Popular Posts/Popular Category). You can only hide/delete the name of these columns if you try the code below: http://screencast.com/t/FbwDKIhN
.td-footer-wrapper .block-title {
display: none;
If you want to have a custom footer to customize it as you like, i will recommend you to use another footer template such as footer template style 5. http://screencast.com/t/ANXhKejS – http://screencast.com/t/NQPWAB7t
For more information about footer settings, please consult our documentation here: https://forum.tagdiv.com/footer-templates/
