For some post on my blog, sidebar doesn’t load and for most, it’s working fine. For example this post
The link is to give you details in real-time so that you can check where the actual mistake is, otherwise, there are many reasons why it could happen. I hope it helps.
The sidebar is present in the page structure, but it seems that there are no widgets inside it. Please note that posts will inherit the sidebar from the primary category
– https://forum.tagdiv.com/primary-category/
Unless a sidebar is set for each post indidivually
– https://www.screencast.com/t/apcLzOD0A
If you did not set a primary category for the post, and the post has only one category, than that will be the primary category from which the sidebar will be inherited. In this case the How to category does not have a sidebar, so the post will not have one as well
– https://technosamigos.com/category/how-to/
Try to either set a sidebar for that category in the Theme panel->Per category settings, or manually set one for the post. Widgets can be added in sidebars in Appearance->Widgets section.
I tried to explain the methods of setting a sidebar for posts, for different situations. There should be no problem displaying any of the available widgets in the sidebar of a post.
Create a new sidebar or edit the existing ones, and enter the widgets you want inside them. Sidebars can be created from multiple places
– https://forum.tagdiv.com/sidebars-tutorial/
Widgets can be entered in sidebars in Appearance->Widgets
– https://www.screencast.com/t/CVOc24mqq77
Then assign the sidebar you want for the post
– https://www.screencast.com/t/zCjwkmn0mz
The post should now have a sidebar, containing the widgets you want in it.
