I upgraded to speedbooster 4.5 recently and now it is not getting activated. What is the script to force activate the speedbooster.
Hello svharishtech,
Please notice that the speed booster is an optional plugin which can be activated in the same way as you install a new plugin.
The Speed Booster works only with the tested plugins. If you use other plugins, it will be automatically disabled, and I suggest to check this first in System Status. However there is a workaround to make it also work with other plugins, you can read more here – https://forum.tagdiv.com/topic/speed-booster-not-compatible-with-vaultpress/
Unfortunately, the time doesn’t allow us tot provide any custom and optimization services. We provide support only for the theme related issues based on Envato support policy – https://themeforest.net/page/item_support_policy I suggest to get someone to help you if you want to optimize your site.
