Forum Fonts
PLEASE.. I beg of you.
Make the fonts of the forum a little bigger. Please…
You can use your browser’s zoom option: http://screencast.com/t/SVEN5wli0M8 Doesn’t that help?
yep.. giving 150% is ok.. can see u better now..
thanks
(some trick for turning to sans-serif? )
Forum is sans-serif by default (if you’re talking about THIS forum).
You can also set the default fonts in your web browser.
Note if you’re using an ooooold web browser, like IE8 you should update to something newer like Chrome.
If you’re using Safari on Windows; that was abandoned by Apple 2.5 years ago and not likely going to work well with much of anything.
If you’re running WindowsXP, you’re going to see some funny gremlins on the web at this point :-0
Hey.. I see sans-serif right now 🙂
Is someone makes fun of me?
use wp 4.1 , I deleting a record of type ” Article ” that remains visible on the home pages.
I have to get into the administration edit and press update the “page” defaut of the home page and the item disappears .
how to solve this problem ?
hi my social counter doesn’t work, can you help me? you can see this problem at planetaim.com it did not think the fans
  • This reply was modified 11 years by planetaim.
Adding unrelated items to a thread may not help you get support quicker.
Best to open a new thread with *your* issue.
@planetaim
your website comes up as blocked by my anti-malware software.
my web site is a informative and entertainment it can’t be blocked as malware.
@Chris
S
social counter does not works
there is somebody who can help solve the problem?
hii i brought newpaper theme yesterday. its very good.
i want to replace these words from my website “Tech And Gadget” “Travel Guide” “Popular Video”
its appear on the home page. my website is not about tech or travel so i want to customize this. i searched in all the place on theme panel but i cant find to edit this.
can you please help me.
can you please help me. and i want to see random post on the homepage, all the things are showing last published article when i scroll down home page am seeing same article with different thumbnail, i want to edit this too.
please help me.
@planetaim
Malwarebytes anti-malware pro for Windows blocks your site loading for containing malware. You may want to contact them about that.
https://www.malwarebytes.org/lp/ip-blocking/?ipblock=true
Your Malwarebytes malicious website blocking technology has blocked outgoing or incoming communication between your computer and a malicious Internet Protocol (IP) address. That’s a good thing. This communication could be:
• An attempt to download malware onto your computer
• An attempt to redirect you to a malicious webpage
• An attempt to deliver malicious advertising
@ganeshdgk
If you have installed demo, this will install new data (menu, posts, categories, pages) and it can only be remover manually. Please use it on development setup.
You can change block title like this: http://screencast.com/t/Jb3QaoMQhfb
Also blocks used on your page can show articles by category and have a sort order: http://screencast.com/t/fbRxHX1eoo6
Please follow our documentation: https://forum.tagdiv.com/newspaper-documentation/
Hi. I need to get the sidebar to move from the bottom of the page to the space beside ‘Sport’ section on my Home Page. http://topic.ie
I also need it to stick like in the demo.
Please advise. I have no coding experience so please explain clearly. Thanks.
@newsguy
The sidebar that you use is for Latest Articles, you need to use Widgetised Sidebar block for page template ” Pagebuilder + Latest Articles + Pagination”(page template that you use) if you want sidebar bellow Big Grid like this: http://screencast.com/t/Pxesu9Kc
Also you can set sidebar to display(Default or your custom sidebar): http://screencast.com/t/5t7i5HxWWDO
To make it sticky please add td-ss-row class to the row where you add the widgetised sidebar: https://forum.tagdiv.com/topic/smart-side-bar-social-button-2/
Please post your issues about newsmag theme in the newsmag section!
hi,
slider is wrong. it doesn’t resize image. if ı don’t use big size image image is looking small
my website is http://www.saniyesinde.net
I have checked your site and your image from Big Slider seems to be ok: http://screencast.com/t/CcUwt3R2R
If you have images smaller than 745x483px you need to use a plugin like like Thumbnail Upscale for that: https://wordpress.org/plugins/thumbnail-upscale/ as WordPress cannot enlarge thumbnails, only make them smaller.
If this is not your issue please provide more details.
Hi. I love this theme, but none of the Visual Composer shortcodes work properly on any of the pages, with the exception of the home page. Please help!!
  • This reply was modified 11 years by Eswyn_G.
Not sure what you mean, do you want to use Visual Composer on post pages?
You could enable it from Settings – Visual Composer – http://screencast.com/t/zmJ6AWIxKkW
If this doesn’t solve the issue please provide more details.
Thank you, Emil G.
Hi I’m newbie how can I change the font for my site title (the one I can edit through appearance>>customize>>site title and tagline from the WP dashboard)?
Good afternoon. On this demo site – http://themeforest.net/item/newspaper/full_screen_preview/5489609
I got this after import – http://31life.ru/
Why so? Where are the other menu items, shop, etc.?
A long wait for help?
Viewing 25 posts - 1 through 25 (of 36 total)
