Gadgets Theme Header Problem.
Hello
In the demo of Gadgets theme the header is looking great…but in the demo installation you haven’t mentioned that header at all. please help how to make same header as given in demo website…
thank you
Hello techpostz,
First of all, I will thank you for your interests in our demos! If you like this demo, you simply install it from demo section from Theme panel, according to our documentation here -> https://forum.tagdiv.com/installing-demos/ I do not exactly understand what you mean through the same header. If you will install this demo you will bring the same layout to your end, as you can see here -> https://www.screencast.com/t/Kuli5rGzbTPB
If is not what you mean, provide more details so I will be able to provide a more accurate response.
Hello
I am talking about top navigation bar i have installed the demo in my site but it is not that good as shown demo version. I have tried all types of navigation models in header bar. but nothing is looking like demo version…I most beautiful part i love in this demo is ..check out below images…Inline image 1 I want this type of navigation bar….i have tried changing all headers and top bars but no use..please help me exactly same top navigation bar like demo.
I dont want this type of top navigation bar…visit : http://www.techpostz.com
Hello
below i have sent you few images …I dont want that navigation bar….http://imgur.com/a/4olRO
I want below navigation bar….which is shown below
View post on imgur.com
I want exactly same navigation bar as shown in above image…like demo version.
Hello techpostz,
I guess that you want to hide your menu and top bar menu, right? If you want to achieve this, please use the code below and place it in Theme panel->Custom CSS area.
.td-header-style-7{
display:none;
Hello
You really don’t understand my concern….I want the navigation bar which u have shown in demo theme…I have tried all 12 styles but that kind of navigation is not there in the theme.. Please help me with navigation which u have shown in demo version.
Please note : I want navigation and i want it as show in demo..
which style should i use..please see the image below and there i have marked the navigation ….exactly same kind of navigation i am looking for …please reply fast ..
https://demo.tagdiv.com/newspaper_gadgets/ in this link you can see the navigation which is full and not boxed one…i want exactly same one…In the image below i have marked it.
Maybe this is all a misunderstanding. If you want to have the exact same design and layout as the demo, you have to install it in the theme panel
– https://forum.tagdiv.com/installing-demos/
From what I can see the demo style is not present on your website.
When you install a demo, the system will import all the theme panel settings and the custom style including the header style. The header style used is style 5 with some modifications through CSS and the theme panel.
This customized header style cannot be selected in theme panel, the demo needs to be installed in order to achieve that result.
Please remove the code my colleague provided, and simply install the demo.
